Triangular Sloping Left Truss
With the Triangular Sloping Left command, the triangular sloping left truss type which is one of the prepared truss types, is drawn quickly. Truss heights are adjusted from the truss settings.
Triangular Sloping Left Truss Schematic Drawing:
Location of the Triangular Sloping Left Command
  • Click on the triangular sloping left command.
  • In the Heights tab , enter the heights h4 for triangular sloping left.
Entering 200 cm for h4 in the height tab of the truss settings
