Single footing, strip footing and mat foundations are designed automatically according to Codes.
International Design Codes
ACI 318-19 : Deep Foundation per ACI 318-19 with ideCAD
TSC 2018 :
Notation in ACI 318-19
dpile = diameter of pile at footing base, in.
D = dead load
E = earthquake load
Eh = effect of horizontal seismic forces
Em = seismic load effect including overstrength
Emh = effect of horizontal seismic forces, including overstrength
Ev = vertical seismic effect applied in the vertical downward directio
F = load due to fluids with well-defined pressures and maximum heights;
L = load due to lateral earth pressure, ground water pressure, or pressure of bulk materials;
Lr = roof live load
Pa = maximum allowable compressive strength of a deep foundation member, lb
R = rain load
S = snow load
W = wind load
ϕ = strength reduction factor
