Rib Detail
Color, size, type, layout and table settings of the text of the rib details are arranged.
General
Specifications - Colors
Steel text
Steel line
Steel ID text
Steel ID circle
Total reinforcement length
Dimension text
Dimension line
Object ID
Object body
Axis ID
Axis
Sets the color of the axis. When the color box is clicked, the appropriate color is selected from the window that opens.
Specifications - Heights
Steel text
Steel ID
Steel - text distance
Steel levels displacement
Dimension text
Dimension - text distance
Object ID
Axis ID
Font
Paper
Paper width
Paper height
Scale (1/X)
Standard paper sizes
Vertical/Horizontal use
Distance between layouts
Left margin
Right margin
Top margin
Bottom margin
Border color
You can choose the border color from the color palette that appears on the screen when you click it. If clicked together with the Shift key, the pen thickness of the relevant color can be adjusted. The pen thickness value entered here is only used in inkjet printers.
Text color
You can choose the color of the text written under the sheet from the color palette that appears when you click it. If clicked together with the Shift key, the pen thickness of the relevant color can be adjusted. The pen thickness value entered here is only used in inkjet printers.
Advanced
Draw steel bar ids
Draw steel lengths
Arrange blocks by name
Draw slab loads
Bent straight reinforcement in foundation details
Anchorage length is 1/4
Enable drawing organizer
All stories
Min. distance between blocks
Distance between lines
Table Settings
Table
Table headers
Text
Steel drawings
Draw steel bar table
Waffle Detail
