Opening a Space in the Box (For a New Wing)
In order to create a space in the safe, it is first necessary to define the space as a polygon.
  • Click the Jump to Support / Object Points row (to be able to follow the dimensions).
  • Click on all objects around the boundaries of the polygon you will draw. The corner points of these objects have become active to jump.
  • Click on the Line Drawing / Polygon and draw the space you will create.
  • Click on the Modify / Transform / Polygon-> Space Transform line.
  • Click on the safe and then on the polygon.
  • A polygon-sized space has been opened inside your safe.
  • Click the Support / Delete Free Jump Points row to cancel the jump points.
