In this tutorial, review analysis results.
1. Use the Analysis Model command from View heading.
2. Select the Own Load from Load Type in the Visualization Dialog.
3. Select the Sheeting Loads.
4. Select the Ey from case/combination list in the Deformation tab.
5. Click the Animate command.
6. Select the Moment 3-3 command from the Component section in the Frame Results tab.
7. Select the G'+Q'+Ex+0.3Ey+0.3Ez from Case/combination list.
8. Open the frame element results dialog.
9. Select the Slab Results and M22 from the Component list in the Shell Results tab.
