Set Trim Algorithm
With the Set Trim Algorithm command, the intersection algorithm is changed for angled object intersections. Object intersection is updated according to the changed trim method.
Location of the Set Trim Algorithm Command
You can access it from the Ribbon menu Modify tab under the Entity Edit heading.
  • Click the Set Trim Algorithm command.
  • Select your object whose trim method is to be changed by clicking with the left mouse button.
  • The trim method of your object will change.
Intersection shape before the set trim algorithm
Choosing the beam to be trimmed
Intersection shape after the set trim algorithm
Set Cantilever
