T-Beam Geometry per ACI 318-19 with ideCAD
How does ideCAD define T-Beam effective flange width according to ACI 318-19?
  • In T-Beam construction, effective flange width is determined and applied automatically.
Notation
bf = effective flange width, in.
h = overall thickness, height, or depth of the member, in.
sw = clear distance between adjacent webs, in.
:check_mark:
In non prestressed T-Beam monolithic concrete construction, the effective flange width bf equals the beam width bw plus an effective overhanging flange width in accordance with ACI Table 6.3.2.1.
Flange location
T-beam overhanging flange width
Eacg side of web
One side of web
h is the slab thickness and sw is the clear distance to the adjacent web.
According to ACI 6.3.2.2, isolated nonprestressed T-beams, as used to provide additional compression area, should have a flange thickness greater than or equal to 0.5bw and an effective flange width less than or equal to 4bw.
:check_mark:
