Defining a Wind Connection
With the Wind Connection command, column-beam connection is defined. It connects the column from the bottom to the beam.
Location of the Wind Connection Command
  • Click the Wind Connection icon from the Connection menu.
  • The wind connection settings dialog will open.
Location of the Wind Connection Settings Dialog
Type Tab
Connection type
Connection type is selected.
Plates
It is chosen whether the plate will be on the left or right or both sides.
Column trim type
It is chosen whether the column trim will be made straight or sloping.
Schematic drawing
Connection and placement values ​​are shown on the schematic drawing.
Preview
Plates Tab
Cap plate
The cap plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Connection plate
Connection plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Vertical plate
The vertical plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Angle Tab
Define plate geometry
If the option is selected, it is determined by entering the angle values. The values ​​to be entered are shown in the schematic drawing.
Use section
By selecting the option, one of the ready-made L profiles is selected from the list as an angle. By clicking on the load section button, you can reach the ready section library and reach the list of American and European finished rolling sections and select from the list.
Schematic drawing
Preview
Connection Bolts Tab
Horizontal arrangement
Group 1
Bolt properties
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode
Schematic drawing
Preview
