Stair Settings
Stair settings are included in the Stair Settings dialog, which includes parameters such as stair type, construction type, material, railing and handrail types . Before the stair is created, the stair settings dialog opens, and the settings made will be valid for the stairs to be drawn from now on.
Location of the Stair Settings Dialog
The stair that appears on the screen after running the Stair command is available in the helper toolbar.
In Architectural Program
In Structural Program
You can reach it under the ribbon menu Concrete tab, Concrete title
Stair Types Tab
Type list
The stairs are organized under folders according to their types. The staircase to be drawn is selected under these folders.
Plan
The plan view of the selected stair is included.
Perspective
It has a three-dimensional view. It is possible to zoom in, zoom out, rotate the 3D image. In this way, the properties of the stairs can be examined in three dimensions.
Inverted stair
By marking it changes the exit direction of the stair flight.
Description
The description written for the stair is displayed on the Description line. User cannot intervene on this line.
Construction Tab
Construction types
One of the straight, folded, bridge board and ramp type stair systems is selected by clicking with the left mouse button.
Riser parameters
D1 is the step cladding nose length, D2 is the riser cladding thickness, D3 is the step cladding thickness. If cladding is not wanted, these values ​​are entered as zero.
Stair cheek parameters
LK1 and LK2 determine the bridge board height. It is shown on the figure. The thickness parameter is the bridge board thickness.
Stair ID
The name of the stair is entered.
Stair elevation
The lower point of the stairs is the elevation measured from the floor base.
Baluster face count
The number of baluster surfaces determines the count of railing vertical surfaces (railing section). If the count of baluster surfaces is 4, the parapet cross section becomes square.
Don’t write step numbers after
The digits after the digit number entered here are not numbered on the stair.
Draw section line
If it is wanted to draw a section line on the stair, it is marked.
Structural Tab
Structural material
Select the structual material to be used in the stair element from the list.
Finite element width
Enter the maximum finite element width to be taken as basis in shell calculation. The ideCAD analyzes shells by dividing them into trapezoidal form finite elements. Finite element width is automatically adjusted according to the shell shape, provided that it does not exceed the value entered in this row.
Draw concrete calculation lines
If it is wanted to show reinforced concrete calculation axes, it is marked.
Appearance Tab
Schematic drawing
Which elements of the stair are defined by line types and colors are shown in schematic drawings and numbering.
Linetypes
A separate line type is selected for the lines forming the stair in the plan. Clicking the down arrow buttons to the right of the boxes opens the list of line types. From this list, the wanted line type is selected by clicking with the left mouse button. The lines are numbered in red on the figure on the left.
Colors
A separate color is chosen for the lines forming the stair in the plan. The lines are numbered in blue on the figure to the left of the dialog. When the color box is clicked, the appropriate color is selected from the window that opens.
Label
By marking the label, the number of risers, riser height and step width are shown on the stair.
The font of the label font and the number of risers, the height and width of the digit is selected.
The text color of the label color and the number of risers, the height and width of the digit is selected.
The number of risers, the height of the digit and the height of the text of the width text are entered on the label height.
The total number of digits is unmarked, and the number of risers, riser height and step width are shown separately on each branch. If checked, total values ​​are shown.
Visual material
The material to be used on the body, cover, handrail and railing surfaces of the stairs is selected from the list. Surfaces are covered with the selected material and displayed as such in renderings.
Texture length is entered into the world length. For example; If 1 is entered, the selected material texture is taken as 1 meter and covered on the relevant walls.
The angle is the angle of the texture.
In the U and V offset, the motion value in the x and y plane of the texture is entered.
With U and V mirroring, the texture is symmetrical with respect to the y and x planes.
By selecting the single material option, the material selected in the "Body" is used on all surfaces of the wall.
Units Tab
Basic units
One of the selections is activated by clicking the left mouse button on the job.
Meter : If checked, the unit of information text will be meters.
Centimeter : If checked, the unit of the callout will be centimeter.
Millimeter : If checked, the unit of callout will be millimeter.
Feet and fractional inches : If checked, the unit of callout is feet and fractional inches. The unit format is, for example, 15 '-10 3/4 ".
Feet and decimal-digit inches : If checked, the unit of callout is feet and decimal-digit inches. Unit format is, for example, 15' -10.7".
Decimal place fit: If checked, the unit of callout will be decimal place fit. The unit format is for example 15.89 '.
Fractional inch: If checked, callout unit will be fractional inch. The unit format is, for example, 1901/2 ".
Inch with decimal places : If checked, the unit of callout is inches with decimal places. The unit format is for example 190.7".
Digit count
It determines how many digits will be shown after the comma. The desired number is selected from the list. For example, if 2 is selected, units will be shown as two digits after the comma. If 0 is selected, units will not be shown after the comma.
Fractions
It determines the precision of the dimension to be made in fractional inch format. In the list, there are options with a sensitivity of 1/2, ¼, 1/8, 1/16, 1/32, 1/34. If "no fraction" is selected, units will appear without fractions.
Rounding interval
It determines the rounding range of the measurement to be made in meters, centimeters or millimeters. If No rounding is selected, the dimensioning is done at exact value. As the range gets larger, the dimensioning is rounded up to the selected range.
Show zero unit
If it is not checked, it does not show the zero and point on the left in dimensioning. For example, it measures 0.20 as 20. If marked, the value 0.20 is scaled as 0.20.
Small fraction text
When fractional inch format is selected, determines the fractional part to display in upper / lower case. If it is checked, the fraction is slightly above the integer and small, if not, the fraction is shown the same size next to the integer.
Show zero foot
Determines whether 0 is displayed in the 0-foot gauge (less than 1 foot gauge). For example, if it is not checked, it will show a measure of 0 '- 15 "as -15". If marked, it shows as 0'-15 ".
Show zero inch on 0-1 inch range
For example, a dimension inch with a value of 8'-0 1/6 "is in the range 0-1. If the option is not ticked, the value 8'-0 1/6" will be displayed as 8'-. In other words, inch values ​​in the 0-1 range will not be displayed.
Show absolute zero inch
Determines whether to show zero inches in the dimension value where inches is absolute zero. For example, a dimension of exactly 10 'will be displayed as 10'-0 "if this option is selected. If not checked, it will be displayed as 10" -.
Handrail - Baluster Tab
Handrail profiles
Select a handrail from the list of handrails by clicking with the left mouse button.
The selected handrail section is displayed on the handrail screen.
Baluster profiles
Select a baluster from the list of balusters by clicking the left mouse button.
The selected baluster image is displayed on the baluster screen.
Components Tab
  • Click the Add Building Component button.
  • In this dialog, click the folder related to the material from the list on the left. Choose the material you want to use.
In the usage section
Following are the lines that appear in the proportion list according to the stair and material size.
Stairs
Measure
Listed
Explanation
Constant
Independent
Length
Independent
Line of travel length
It means that the length of the material will be found by multiplying the length measurement found when defining the material and the length of the exit line of the ladder.
Area
Independent
The area measure found when defining the material will be used exactly as the area of ​​the material.
Top area
It means that the area measure found when defining the material will be multiplied by the area of ​​the upper surface of the ladder.
Volume
Independent
The volume measure found when defining the material will be used exactly as the volume of the material.
Count
Independent
The number measure found while defining the material will be used exactly as the material number.
Count
Riser count
The number measure found when defining the material will be used by multiplying the number of rises of the stair.
Creating a Stair
