Development of Reinforcement.
For reinforcement bars, development length is calculated automatically in accordance with Codes.
İnternational Design Codes
ACI 318-19 : Development of Reinforcement
TSC 2018 : TSC Development of Reinforcement
Symbols in ACI 318-19
ψe = factor used to modify development length based on reinforcement coating
ψg = factor used to modify development length based on grade of reinforcement
ψs = factor used to modify development length based on reinforcement size
ψt = factor used to modify development length for casting location in tension
Ktr = transverse reinforcement index, in.
Atr = total cross-sectional area of all transverse reinforcement within spacing s that crosses the potential plane of splitting through the reinforcement being developed, in.2
f'c = specified comprehensive strength of concrete, psi
Splices.
