Draw Similar Entity
With the Draw Similar Entity command, an object similar to the selected object is drawn. The drawn object has the same properties as the selected object.
Location of Draw Similar Entity Command
You can access the Draw Similar Entity command from the right-click menu.
  • Select the object you want to draw with the same properties.
  • Click the draw similar entity command from the drop-down menu.
  • The ideCAD will enter the command of the relevant object and wait ready to be drawn.
Set Trim Algorithm
