In the steel design result dialogs, the axial force and biaxial bending (PMM) ratio of the steel elements are shown along with the internal force values.
With ideCAD Structural, steel structures are analyzed and designed with the DGT approach. With TBDY 2018, steel elements are designed in accordance with the Design, Calculation and Construction Principles of Steel Structures (GKT and YDKT), AISC 360-16 (ASD and LRFD), TS EN 1993-1-1 (Eurocode 3) regulations. Steel column, beam, purlin, steel tie, castellated beam, crane beam, composite slab, secondary beam, truss, brace and connections are designed.
Steel Column Design Results -
Steel Beam Design Results -
Secondary Beam Design Results -
Composite Castellated Beam Results -
Noncomposite Castellated Beam Design Results -
Composite Beam Design Results -
Crane Beam Design Results -
Purlin Design Results -
Brace Design Results -
Truss Design Results -
Space Truss Design Results -
Steel Joist Design Results -
Space Purlin Design Results -
Connection Design Results -
Moment Resisting Frames -
Concentrically Braced Frames -
Clash Check
