How does ideCAD calculate Two-Way slab design strength according to ACI 318-19?
Both flexural moment and shear strength is controlled automatically according to 8.5.1.1.
Dimensions of the cross-section should be satisfy ACI Eq. (22.5.1.2). It’s automatically controlled and users are warned if the rule is not satisfied.
Mn = nominal flexural strength at section, in.
Msc = factored slab moment that is resisted by the column at a joint, in.-lb
f'c = specified comprehensive strength of concrete, psi
Ac-sh = area of concrete used to determine shear stress, in2
γf = factor used to determine the fraction of Msc transferred by slab flexure at slab-column connections
To design two-way slab under flexural moment, two-way slab design strength is provided ΦSn ≥ U. Both flexural moment and shear strength are controlled according to 8.5.1.1.
ΦMn ≥ Mu at all sections along the span in each direction
ΦMn ≥ γfMsc within bslab 8.4.2.2.3 (flat slab)
Φvn ≥ vu at the critical sections defined 8.4.4.1 for two-way shear (flat slab)
Φ is automatically designed according to Strength Reduction Factors per ACI 318-19 with ideCAD.
Moment
Mn is determined according to 22.3 as nominal flexural strength Mn is calculated as shown below. Detailed information: Flexural Strength per ACI 318-19 with ideCAD
Openings in slab systems
ACI 22.6.4.3 is provided when an opening is placed at least 4h from the face of a column, concentrated load or reaction area. Detailed information: Two-Way Shear Strength per ACI 318-19 with ideCAD .
