Dome Drawings
Drawings of domes whose calculation axes have been defined and analyzed can be prepared by using the Dome Drawings command.
Location of the Dome Drawings Command
  • Click on the Dome Drawings icon.
  • The drawing properties dialog will open. If there is a different situation in this dialog, change the parameters related to the drawing.
  • When you click the OK button, the dome drawing will be created.
General Tab
Specifications - Colors
Background color
Rebar text
Sets the color of the rebar text. When the color box is clicked, the appropriate color is selected from the window that opens.
Rebar line
Sets the color of the reinforcement line. When the color box is clicked, the appropriate color is selected from the window that opens.
Rebar ID text
Adjusts the color of the rebar ID text. When the color box is clicked, the appropriate color is selected from the window that opens.
Rebar ID circle
Adjusts the color of the rebar ID circle. When the color box is clicked, the appropriate color is selected from the window that opens.
Dimension text
Sets the dimension text color. When the color box is clicked, the appropriate color is selected from the window that opens.
Dimension line
Sets the dimension line color. When the color box is clicked, the appropriate color is selected from the window that opens.
Object ID
Object body
Specifications - Appearance
Rebar text
The height of the rebar text is entered.
Rebar levels displacement
The distance between the two rebar texts is entered.
Dimension text
Object ID
Rebar font
The rebar font is selected.
Dimension font
Dimension font is selected.
Object ID font
Object ID font is selected.
Dimension marker type
The dimension marker type is selected.
Advanced Tab
Draw rebar ID’s
If checked, rebar ID’s are shown in the drawings. If not checked, it will not be displayed.
Arrange blocks by name
Generate elevations
If checked, elevations are shown in the drawings. If not checked, it will not be displayed.
Min. distance between blocks
Distance between lines
Paper Tab
Paper width
Paper height
Scale (1/X)
Standard paper sizes
Vertical/Horizontal use
Distance between layouts
Left margin
Right margin
Top margin
Bottom margin
Annotations Tab
Defined annotations are listed.
Preview
There is a preview of the annotation selected from the list.
Annotation width
Annotation width is determined.
Layout number
The layout number is determined.
Create New
The new annotation is created.
Edit
The annotation is edited.
Delete
The annotation is deleted.
Don’t add annotation block to the layout
If it is checked, annotation will not be added to the layouts.
