New Layout Block-All Drawing
With the New Layout Block-All Drawing command, all of the drawings in the drawing window are made into block at once and saved in memory or archive.
Location of New Layout Block - All Command
You can access it under the ribbon menu drawings tab, Layout Design title.
  • Click the New Layout Block - All icon.
  • Click any point in the drawing area. The point you click will be the insertion point of the block.
  • The Layout Block Settings dialog will open. In this dialog, give a block name and set the scale.
  • If you leave the Save to library line checked, the block will be saved in the archive.
  • Click the OK button.
Determination of insertion point
Layout block creation
