Trapezoid Sloping Symmetric Truss
With the Trapezoid Sloping Symmetric command, the trapezoid sloping symmetric truss type which is one of the prepared truss types, is drawn quickly. Truss heights are adjusted from the truss settings.
Trapezoid Sloping Symmetric Truss Schematic Drawing:
Location of the Trapezoid Sloping Symmetric Command
  • Click on the trapezoid sloping symmetric command.
  • In the Heights tab , enter the heights h1, h2, h3 and h4for trapezoid sloping symmetric.
Entering 80 cm for h1, h2, h4 and 100 cm for h3 in the height tab of the truss settings
