Coupling Beam Design.
  • Boundary Elements of Special Structural Wall requirements are met automatically
International Design Codes
ACI 318-19 : Coupling Beam Design per ACI 318-19 with ideCAD (v12)
TSC 2018 :
Notation in ACI 318-19
Ach = cross-sectional area of a member measured to the outside edges of transverse reinforcement, in.2
Acv = gross area of concrete section bounded by web thickness and length of section in the direction of shear force considered in the case of walls, and gross area of concrete section in the case of diaphrams. Gross area is total area of defined section minus area of any openings, in.2
Acw = area of concrete section of an individual pier, horizontal wall segment, or coupling beam resisting shear, in2.
Ash = total cross-sectional area of transverse reinforcement, including crossties, within spacing s and perpendicular to dimension bc, in.2
bc = cross-sectional dimension of member core measured to the outside edges of the transverse reinforcement composing area Ash, in.
c1 = dimension of rectangular or equivalent rectangular column, capital, or bracket measured in the direction of the span for which moments are being determined, in.
c2 = dimension of rectangular or equivalent rectangular column, capital, or bracket measured in the direction perpendicular to c1, in.
hwcs = height of entire structural wall above the critical section for flexural and axial loads, in.
so = center-to-center spacing of transverse reinforcement within the length lo, in.
α = angle definin the orientation of reinforcement
