With the Stiffened End Plate Connection command, beam-beam connection is defined.
Location of the Stiffened End Plate Connection Command
From the Connection menu, click on the Stiffened End Plate Connection icon.
The stiffened end plate connection settings dialog will open.
Location of the Stiffened End Plate Connection Settings Dialog
General Tab
End plate
End plate is determined by entering values. The values to be entered are shown in the schematic drawing. |
Common
The distances in both plates are adjusted at once. |
Shim
Shim is a plate placed between the elements to be connected in bolted connections. If shim is to be made, the option is selected and t2, thickness value is given. |
Connection plate Connection plate is determined by entering values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Stiffener Tab
Stiffener plates
The stiffener plates are determined by entering the values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Chamfers Tab
Chamfer (c1)
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode The strengths of the welding electrodes are defined in the design inputs. The strength of the main element in the weld connection is controlled under the condition that it has less strength than the weld strength. To create the welding electrode, provide the information "Name" and "Weld metal tensile strength" in the dialog that opens after clicking "Create New". Welding geometry is determined automatically by the program. These properties can be changed to easily determine the connection properties. Geometry features are in accordance with industry standards and in the form specified in AISC.
Schematic drawing
Preview
Bolts Tab
Horizontal arrangement
The horizontal arrangement distance value of the bolts is entered. The values to be entered are shown in the schematic drawing. |
Group 1
Bolt properties
Schematic drawing
Connection and bolt arrangement values are shown on the schematic drawing. |
Preview
Design Data Tab
