The Edit Railing Elevation command edits the elevation of the railing at the nodes of a drawn railing.
Location of Edit Railing Elevations
You can access it under the ribbon menu Home tab, Entities title.
Define a railing.
Click the Edit Railing Elevations icon in the ribbon menu .
Nodes will appear on the railing.
Move the cursor over any node and click the node.
A dialog will open in which the elevation value can be entered.
Enter the elevation value and click the OK button.
The elevation of the operation point will change.
Similarly, adjust the elevation of other nodes according to your needs.
Before editing railing elevations
Choosing the node point
Entering the elevation value
After editing railing elevations
