Remove Inner Cut of Edge
Remove Inner Cut of Edge command removes the gap created by define inner cut to edge on the sweep.
Location of Remove Inner Cut of Edge
You can access it from the Ribbon menu Modify tab under Entity Edit title.
  • Click the Remove Inner Cut of Edge icon.
  • Click on the edge of the sweep that was previously cut.
  • Define inner cut to edge will erase the gap created.
The initial version of the sweep
Selecting the edge of the cut sweep
Selection of the inside cut for erasing
Deletion of the gap created with define inner cut to edge
