In this tutorial, fix the failures.
1. Use the Analysis+Design (F9) command.
2. Open the Concrete All Failures list.
3. Use the Concrete Column-Beam Joint Area command.
4. Open the Column Settings.
5. Change the column dimensions.
6. Open the story 1 ceiling page.
7. Open the Column Settings.
8. Change the column dimensions.
9. Use the Analysis+Design (F9) command.
10. Open the Concrete All Failures list.
11. Use the Concrete Column-Beam Joint Area command.
