With the Joining Plates Connection command, beam-secondary beam connection is defined.
Location of the Joining Plates Connection Command
From the Connection menu, click on the Joining Plates Connection icon.
The joining plates connection settings dialog will open.
Location of the Joining Plates Connection Settings Dialog
Plates Tab
Type
For the connection, one of the bolted or welded connection types is selected. |
Plate 1
The first plate is determined by entering the values. The values to be entered are shown in the schematic drawing. |
Plate 2
The second plate is determined by entering the values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Brackets Tab
Bracket 1
It is determined by entering the values for the bracket 1. The values to be entered are shown in the schematic drawing. |
Bracket 2
It is determined by entering the values for the bracket 2. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Bottom Plates Tab
Plate 1
Plate 1 dimensions are determined by entering values. The values to be entered are shown in the schematic drawing. |
Plate 2
Plate 2 dimensions are determined by entering the values. The values to be entered are shown in the schematic drawing. |
Web shim Shim is a plate placed between the elements to be connected in bolted connections. If shim is to be made, the option is selected and t 4 , thickness value is given. |
Schematic drawing
Preview
Chamfers Tab
Chamfer (c1)
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode The strengths of the welding electrodes are defined in the design inputs. The strength of the main element in the weld joint is controlled under the condition that it has less strength than the weld strength. If necessary, click the list and define "Create New…". To create the welding electrode, give the information "Name" and "Weld metal tensile strength" in the dialog that opens after clicking "Create New". Welding geometry is determined automatically by the program. These properties can be changed to easily determine the connection properties. Geometry features are in accordance with industry standards and in the form specified in AISC.
Schematic drawing
Preview
Stiffener Plates Tab
Stiffener plates
The stiffener plates are determined by entering the values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
There is a preview of the connectipn. The selection made and the entered values can be followed simultaneously in the preview. |
Bolts Tab
Horizontal arrangement
The horizontal arrangement distance value of bolts is entered. The values to be entered are shown in the schematic drawing. |
Group 1
Group 2
Group 3
Bolt properties
Schematic drawing
Preview
Design Data Tab
