Parallel Copy with Offset
A parallel copy of the 2D drawing elements, such as line, circle, arc, etc, is created at a certain distance as the given value with the "Offset" command.
Usage steps:
  • Click the Offset icon from the toolbar.
  • Enter the offset value in the offset distance box in the toolbar that opens.
  • Select the object.
  • Click in the drawing area to determine the offset direction.
  • Press the right mouse button to finish.
