Building Performance Targets per ASCE 7-16, FEMA P-695, and NIST
The commentary to ASCE 7 quantifies the intended performance for buildings in different Risk Categories. The below Table summarizes the anticipated reliability values. These values have not been validated with experience or in-depth analysis, but instead are notional values that represent the intent of 48 the building code committee. FEMA P-695 (2009) also suggests that the probability of collapse due to MCER ground motions should be limited to 10% for Risk Category II buildings. FEMA P-695 presents a detailed methodology for determining the collapse probability of classes of buildings. Several case studies have used the methodology to benchmark the performance of modern buildings, with results reported in FEMA P-695 (2009) and NIST (2010).
Risk Category
Probability of Total or Partial Collapse ( % )
Probability of Failure that could result in endangerment of individual lives ( % )
I & II
10
25
III
6
15
IV
2.5
10
Firstly, ASCE 7-16, the earthquake design values for most locations in the United States, have been adjusted so that structures having standard collapse fragility will have a collapse probability of 1% in 50 years.
According to ASCE 7-16, target reliability values for structural stability caused by an earthquake due to MCER earthquake ground motion is given below.
Risk Category
Conditional Probability of Failure ( % )
Conditional Probability of Component or Anchorage Failure ( % )
I & II
10
25
III
5
15
IV
2.5
9
