Part 45. Check Geometry and Failure
In this tutorial, check geometry and failure.
1. Use Geometry Check command.
2. Select the option from the Checklist window.
3. Check the incorrectly data entry that listed.
4. Use the Auto Label Entities command.
5. Check the Set other stories' labels by assuming this story as base for same entities.
6. Check the Generate other stories' labels for unmatched entities.
7. Select all elements.
8. Select the Down to up from the Labeling direction horizontal scan section in the axis tab.
9. Use Geometry Check command.
10. Select the option from the Checklist window.
11. Check the incorrectly data entry that listed.
