Trapezoid Sloping Asymmetric Truss
With the Trapezoid Sloping Asymmetric command, the trapezoid sloping asymmetric truss type which is one of the prepared truss types, is drawn quickly. Truss heights are adjusted from the truss settings.
Trapezoid Sloping Asymmetric Truss Schematic Drawing:
Location of the Trapezoid Sloping Asymmetric Command
  • Click on the trapezoid sloping asymmetric command.
  • In the Heights tab , enter the heights h1, h2, h3 and h4for trapezoid sloping asymmetric.
  • In the Lengths tab, enter the l 1 for apex of truss.
Entering 80 cm for h1, h2, h4 and 75 cm for h3 in the height tab of the truss settings
Entering 800 cm for the l1 value in the dimensions tab
Flat Truss
