Shear Wall Combined Flexural and Axial Design.
  • Three-dimensional interaction failure surface of a column is calculated automatically.
International Design Codes
ACI 318-19 : Shear Wall Combined Flexural and Axial Design per ACI 318-19 with ideCAD
TSC 2018 : Design Moment Strength for Shearwalls
Notation in ACI 318-19
Ast = total area of nonprestressed longitudinal reinforcement, in2
α = depth of equivalent rectangular stress block, in.
Cs = reinforcement tension force, lb
D = dead load
E = earthquake load
L = live load
Lr = roof live load
Pn,max = maximum nominal axial compressive strength of a member, lb
Pnt = nominal axial tensile strength of member, lb
Pnt,max = maximum nominal axial tensile strength of member, lb
Po = nominal axial strength at zero eccentricity, lb
R = rain load
S = snow load
W = wind load
ϕ = strength reduction factor
εt = net tensile strain in extreme layer of longitudinal tension reinforcement at nominal strength, excluding strains due to effective prestress, creep, shrinkage, and temperature
β1 = factor relating depth of equivalent rectangular compressive stress block to depth of neutral axis
