Distance Setting
When the distance is not adjusted, the door/window is placed at any point on the wall by clicking the left mouse button. With the Use Distance command, the door/window is placed as far from the wall as the specified distance. With the Use Dio Reference command, the placement is made by considering the existing door/windows. Use dio reference command can only be used when the use distance command is activated.
Location of Use Distance Command
You can access it from the Door/Window toolbar.
Location of Use Dio Reference Command
Use distance value 20 cm
Use distance value 50 cm
Use distance value 50 cm when use dio reference is active
Use distance value 100 cm when use dio reference is active
