Part 51. Review Concrete Design
In this tutorial, Review Concrete Design.
1. Use the As(-) Concrete Insufficient Rebar Area command from Output heading.
2. Select the All Failures from Design Output list in the Visualization dialog.
3. Use the Longitudinal rebar pursantage (%-Columns) from Concrete list.
4. Use the Column command from the Design heading.
5. Check the Columns, Forces-Reinforcement Areas, Capacity Diagrams and Moment-Curvature tab.
6. Activate the Caltrans idealized model and stop when a fiber reaches ultimate stress options in the Moment-Curvature tab.
7. Use the Beam command from the Design heading.
8. Check the Beams, Concrete Configuration, Reinforcement Areas, Forces & Details and Deflection & Crackings tab.
9. Use the Slab command from the Design heading.
10. Check the Slabs tab.
