You can import the DWG/DXF format drawings you received from the architect and use them as a base in the ideCAD Structural program.
Click the ideCAD logo in the upper left corner of the program.
Click on the Import/DWG/DXF-2D line from the menu that opens.
Select the DWG format file you received from the architect and click the Open button.
The Import Options dialog will open.
In the dialog, set the necessary parameters and click the OK button.
The rename layer dialog will open and you will be asked what to do for layers with the same name.
Select rename new layer option and click OK button.
Architectural project drawings will be uploaded.
