Baseboard Settings
With the Baseboard Settings command, the alignment type, elevation, material and drawing settings of the baseboard object can be accessed.
Location of Baseboard Settings Command
After clicking the baseboard icon from the sweep toolbar, you can access the baseboard settings by clicking the settings icon.
General Tab
Alignment
The position of the baseboard in the story is adjusted. If "Story top" is marked, the baseboard is placed on the story ceiling. If "User defined" is marked and the elevation is given, the baseboard is drawn according to the story floor, as high as the entered level.
Place sweep
The position of the baseboard according to the section is adjusted with inner and outer options. If the outer is marked, the baseboard is drawn based on the outer edge of the section, if the inner is marked, the inner edge is taken as basis.
Color
Select the color of the baseboard from the dialog that opens when clicked.
Material
For the solid model, select the material (texture) of the baseboard surfaces from the drop-down list.
Texture length of the material used is entered into the texture world length. For example; If 1 is entered, the selected material texture width is taken as 1 unit and covered on the relevant walls. Considering that the texture is in the form of a square, the object surfaces are covered with 1x1 textures arranged side by side. It can be determined separately for each surface.
Invisible edge line type
Select the linetype of the background lines from the list. You can cover (make invisible) any edge of the baseboard. You may want to make the line types of the edges that you make invisible, different from other edges.
Project profiles
It is a list of profiles for baseboard. The selected profile will be used in the enclosure. Profile preview is drawn on the right.
Schematic section
Includes the dimensioned drawing of the selected section.
3D preview
It is the 3-dimensional view of the baseboard. You can rotate the image around itself by holding down the left mouse button and moving it. You can zoom in and out by holding the right mouse button and moving the mouse.
Components Tab
  • Click the Add Building Component button.
  • In this dialog, click the folder related to the material from the list on the left. Choose the material you want to use.
In the usage section
Following are the lines that appear in the proportion list according to the wall object and material size.
Baseboard
Measure
Listed
Explanation
Constant
Independent
Length
Independent
Length
It means that the length of the material will be found by multiplying the length measure found when defining the material and the length of the baseboard.
Area
Independent
It means that the area measure found while defining the material will be used exactly as the amount.
Outside area
It means that the area measure found while defining the material will be used by multiplying it with the baseboard outside area.
Volume
Independent
The volume measure found when defining the material will be used exactly as the volume of the material.
Volume
It means that the volume measure found when defining the material will be used by multiplying the baseboard volume.
Count
Independent
The count measure found while defining the material will be used exactly as the material number.
Count
It means that the count measure found when defining the material will be multiplied by the number of baseboard.
