Text settings are accessed from the Text Settings command. The font color, height, type and distance between lines are adjusted according to the project design.
Location of the Text Settings Dialog
Text Command Settings
You can access it under Text in the Drawings tab of the Ribbon menu.
You can also access it by clicking the Settings icon in the text auxiliary toolbar that appears after the text command is run.
Height The height of the text is entered. |
Distance between lines
The distance between the two text lines is entered. |
Color The color of the text is chosen. When the color box is clicked, the appropriate color is selected from the window that opens. |
When the button is clicked, the "Font Settings" dialog appears. Font of information text can be set here. |
Text Object Settings
Select the text you want to enter its settings, click the right button of the mouse and click the Properties line from the menu that opens. Edit text dialog which include the text settings, will open.
Also Double-clicking on a text opens the edit text dialog which include the text settings.
Edit Text Dialog
Editing the text
Text editing is done. Changes such as height, color, font, etc. are not reflected here. |
Text selection
When you want to change more than one text by selecting it, the selection keys are activated. You can switch between the next, previous, last and first texts. |
Distance between lines The distance between the two text lines is entered. |
