Defining a Brace Corner Connection
With the Brace Corner Connection command, the brace corner connection is defined.
Location of the Brace Corner Connection Command
When the steel brace is defined, the program makes these connections automatically. However, the connection made automatically can be deleted and a new one can be made.
  • From the Connection tab, click the icon Brace Corner Connection.
  • From the 3D perspective view, first click the brace and press the right mouse button.
  • Then click the crossbars and/or beams respectively.
Location of the Brace Corner Connection Settings Dialog
Main Plate Tab
Plate dimensions
The dimensions of the plate are determined by entering the values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Brace Connection Tab
Type
Connection type is selected.
Dimensions
Schematic drawing
Preview
Brace types
Bolts Tab
Horizontal arrangement
The horizontal arrangement distance value of bolts is entered. The values ​​to be entered are shown in the schematic drawing.
Group 1
Bolt properties
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode
Welding geometry is determined automatically by the program. These properties can be changed to easily determine the joint properties. Geometry features are in accordance with industry standards and in the form specified in AISC.
Schematic drawing
Preview
Design Data Tab
Angle Tab
The Angle Tab becomes active when the Use angle plate option is selected on the Main Plate tab.
Define plate geometry
If the option is selected, it is determined by entering the angle values. The values ​​to be entered are shown in the schematic drawing.
Use section
By selecting the option, one of the ready-made L profiles is selected from the list as an angle bracket. By clicking on the Load section button, you can reach the ready section library and reach the list of American and European finished rolling sections and select from the list.
Length
Angle length value is entered.
Schematic drawing
Preview
Angle Bolts Tab
The Angle Bolts Tab becomes active when the Use angle plate option is selected on the Main Plate tab.
Group 1
Bolt properties
Schematic drawing
Preview
