Creating Circles
The circle is the object used to create a circular elongated object drawn in the XY plane. It has a single node at its center.
To create a circle;
  • Click the Line Drawing / Circle .
  • In the dialog box that opens, set the number of circle points. The more dots there are, the smoother the circle will be.
  • Click the point that will be the center of the circle in the plan window.
  • You will see that the circle starts to draw when you move the mouse. Move away from the center by the radius of the circle and click. The circle will be formed.
To make changes to the existing apartment;
  • Click on the circle. The circle will turn green. A red box will appear at the center joint. Click on the node and move the circle where you want it.
  • You can turn the circle into an extended object with the stretch command.
