Time History Analysis
After defining the time history function, state and combinations, it is calculated with the Analysis Design command in the time history area.
Location of Analysis Design Command
Ribbon menu Analysis and Design tab Analysis title under Analysis Design can be found on command.
  • Define the time history function, state, and combinations.
  • Click the analysis design command.
  • Do you want to perform analysis option will open.
  • When the OK button is clicked, the analysis + design process will start.
  • In the structural analysis status window, the steps and process times applied during the analysis + design process are given for information purposes.
