For example,
SBR001 BASE STORY Slenderness check failure.
For members designed based on compression, or tension, the effective slenderness ratio control is made according to CYTHYE 2016 (GKT & YDKT), AISC 360-16 (ASD & LRFD), or EN 1993-1-1 codes.
According to AISC 341-16 and AISC 360-16, the effective slenderness ratio KL/r ≤ 200 for compression members should be satisfied.
According to AISC 341-16 and AISC 360-16, the effective slenderness ratio KL/r ≤ 300 for tension members should be satisfied.
ideCAD Structural automatically checks the slenderness ratio according to axial tension or compression conditions.
Solutions:
Brace length can be reduced. If the element length is reduced, the axial compressive strength increases.
Steel element cross-section can be enlarged.
K: effective length factor
L: laterally unbraced length of the member
r: radius of gyration
