Triangular Sloping Right Truss
With the Triangular Sloping Right command, the triangular sloping right truss type which is one of the prepared truss types, is drawn quickly. Truss heights are adjusted from the truss settings.
Triangular Sloping Right Truss Schematic Drawing:
Location of the Triangular Sloping Right Command
  • Click on the triangular sloping right command.
  • In the Heights tab, enter the heights h4 for triangular sloping right.
Entering 200 cm for h4 in the height tab of the truss settings
