Longitudinal and Transverse reinforcement limits are controlled automatically.
İnternational Design Codes
ACI 318-19 : Column Reinforcement Limits per ACI 318-19 with ideCAD
TSC 2018 : Column Longitudinal Reinforcement Detailing Column Transverse Reinforcement Detailing and Limits
Ach = cross-sectional area of a member measured to the outside edges of transverse reinforcement, in.2
Ash = total cross-sectional area of transverse reinforcement, including crossties, within spacing s and perpendicular to dimension bc, in.2
Av,min = minimum area of shear reinforcement within spacing s, in.2
bc = cross-sectional dimension of member core measured to the outside edges of the transverse reinforcement composing area Ash, in.
db = nominal diameter of bar, wire, or prestressing strand, in.
hx = maximum center-to-center spacing of longitudinal bars laterally supported by corners of crossties or hoop legs around the perimeter of a column or wall boundary element, in.
kf = concrete strength factor
kn = confinement effectiveness factor
lo = length, measured from joint face along axis of member, over which special transverse reinforcement must be provided, in.
nl = number of longitudinal bars around the perimeter of a column core with rectilinear hoops that are laterally supported by the corner of hoops or by seismic hooks.
so = center-to-center spacing of transverse reinforcement within the length lo, in.
ϕ = strength reduction factor
ρs = ratio of volume of spiral reinforcement to total volume of core confined by the spiral, measured out-to-out of spirals
Minimum and maximum longitudinal reinforcement
Minimum shear reinforcement
