The user can reflect their own menu to the ideCAD with customize. Arranges toolbars and menus as desired. It can create new toolbars, add or remove icons. Can add or remove commands from menus.
Location of Customize Command
The customization process is done in the Customize dialog. The user can open the Customize dialog in two ways.
You can access it under the Tools menu Customize title.
You can also click the right button of the mouse on any command to access the Customize command.
Commands Tab
You can drag any icon from the commands listed by category and drop it on the new / existing toolbar.
Categories
Commands are categorized according to the menu order. |
Commands
It contains commands in the selected category. |
Description Provides information about the selected command. |
Toolbars Tab
Toolbars are listed on this tab. Some toolbars are highlighted in the list. Checked toolbars appear in the program. Otherwise it will not appear.
In addition, the program includes automatic toolbar management. Floating toolbars appear automatically, some are not, depending on the command being studied. For example, while in column command, column floating toolbar is opened by the program. It is closed after exiting the command.
The user opens the toolbars whenever they want and closes them whenever they want.
Toolbars
Available toolbars are listed. |
Reset Resets the changes made in the menu. |
Reset all Resets all toolbars and menus. |
New Creates a new toolbar. |
Rename It changes the name of the newly added toolbar. |
Delete Deletes the selected toolbar. |
Show text labels The help that occurs when waiting on an icon in the toolbar for a while appears. |
Keyboard Tab
The list of all commands appears in categories on the Keyboard tab. The user chooses the command they want. It gives information about the command in the description part. Shown if there are any shortcuts defined under available keys. The key or keys that they want to assign from the keyboard are pressed. Information on whether the assigned shortcut key is defined in another command is given under the Press new shortcut key section.
Category Commands are categorized according to the menu order. |
Commands
Current keys
Displayed if there are any shortcuts defined. |
Press new shortcut key The shortcut to be newly defined is entered. |
Assign The new shortcut entered is assigned. |
Remove Cancels an assigned shortcut. |
Reset all Cancels all assigned shortcuts. |
Menu Tab
Features of the display styles of the menus are included.
Application frame menus
Clicking on Reset will bring the menu into its original state. |
Menu animation It adds animation to the opening of the lists in the menus. |
Menu shadows Provides a shaded image when hovering over lists. |
Options Tab
There are properties of the way they display toolbars.
Show screen tips on toolbars An explanation box appears when the icon is hovered. |
Show shortcut keys in screen tips An explanation box appears when the icon is hovered. |
Large icon The icons grow larger. |
