Unstiffened Seated Connection
Unstiffened seated connection is a type of connection that connects two profiles to each other with two angles (cornier or L profile). Bolt control, weld control and plate control are performed automatically according to the placement of the elements of the connection. Unstiffened seated connection design is made automatically according to the Design, Calculation and Construction Principles of Steel Structures (ÇYTHYEDY) (GKT and YDKT) or AISC 360-16 (ASD and LRFD) regulations and the connection report is created.
Weld thickness control is performed as a geometry control in the calculation of the brace and plate connection. As a strength control, yielding in the beam body, wrinkling in the beam body, angle shear yielding and support welding strength are checked.
Connection Geometry
Geometry Checks
Weld Thickness
ÇYTHYEDY 13.3.7
8 mm
3.5 mm
Table 13.4
Strength Checks
Beam Web Yielding
7.1 mm
25.7 mm
10.7 + 15 = 25.7 mm (Beam flange + Beam flange radius)
235.359 N/mm2
ÇYTHYEDY 13.25b
Required
Avalaible
Ratio
Control
73.288 kN
100,207 kN
0.731
Beam Web Crippling
7.1 mm
10.7 mm
25.7 mm
d
300 mm
E
205939650 kN/m2
235.359 N/mm2
ÇYTHYEDY 13.26b
Required
Avalaible
Ratio
Control
73.288 kN
98.138 kN
0.747
Angle Shear Yield
235.359 N/mm2
ÇYTHYEDY 13.17
Required
Avalaible
Ratio
Control
Required
Avalaible
Ratio
Control
73.288 kN
141,215 kN
0.519
Weld Strength at Support
480000 kN/m2
w
11.315 mm
362.846  N/mm2
l
110 mm
e
60mm
Required
Avalaible
Ratio
Control
73.288 kN
74.06 kN
0.990
