Double Vault Truss
With the Double Vault command, the double vault truss type which is one of the prepared truss types is drawn quickly. Truss heights are adjusted from the truss settings.
Double Vault Truss Schematic Drawing:
Location of the Double Vault Command
  • Click on the double vault command.
  • In the Heights tab , enter the heights h1, h2, h3 and h4 for double vault.
Entering 150 cm for h1, h2, h4 and 200 cm for h3 in the height tab of the truss settings
Sloping Vault Truss
