Editing Stair Settings
Stair setting are editing on the scaffolding stair settings. The stair settings are accessed from the stair tab of the scaffolding settings dialog.
Location of Stair Settings
Select the scaffolding for which you want to change the stair settings and click the right mouse button. Click Properties from the right-click menu that opens .
Stair Settings
Dimensions
Since the partition length and height values ​​are based on the stair length and height, you can adjust the length of your stair flight by determining the lower and upper landing lengths.
Add stair
If marked, stairs are added to the stories.
First step
If marked, a step is added to the lower landing.
Last step
If marked, a step is added to the upper landing.
Step count
The number of stair steps is determined.
Elevation
The stair elevation is determined
Sections
Section selection is made by partition the beam settings carrying the stair.
  • Enter the scaffolding settings dialog.
  • Enter the stairs tab.
  • Edit the stair settings.
  • Your scaffolding will change according to the changes you make.
Scaffolding view before changing stair settings
Scaffolding view after changing the landing lengths to 50 cm
Scaffolding view after the step count is 12
Scaffolding view after add stair unchecked
