Connection Design Results
Steel Connection design results and inadequacies of steel connections are displayed in the Steel Connections dialog. In the Steel Connections dialog, the design ratio of the steel connections, the connection type and the combinations are displayed as summary information.
Location of the Steel Connections Dialogue
After the analysis is done, you can access it by clicking the Connection command under the Steel Design title of the ribbon menu Analysis and Design tab .
Steel Connections
Connection
It is the sequence number of the combination.
Elements
The combinations in the project are listed with their names.
Combination type
The name of the connection type.
Geometry check
Indicates whether the geometry control provides.
Combination
It shows the most unfavorable combination of connection design.
Ratio
Capacity ratio.
Strength check
Indicates whether it provides strength check or not.
