Remove Stair Concrete Calculation Line
The concrete calculation line defined on the stair are deleted with the Remove Stair Concrete Calculation Line command.
Location of Remove Stair Concrete Calculation Line Command
You can reach it under the Concrete tab in the ribbon menu under the Concrete heading.
  • Click the Remove Stair Concrete Calculation Line icon for the stairs .
  • Click on one of the calculation line defined on the stair.
  • The line will be deleted.
Stair before calculation line is deleted
Selecting the calculation line to be deleted
Stair after calculation line is deleted
