The condition ∑Mdev / M0> = 0.75 at mixed ductility level could not be met.
The Complete Message:
The condition ∑Mdev / M0> = 0.75 at mixed ductility level in X / Y direction could not be met.
According to article 4.3.4.6 of TBDY , ductility level should be provided in mixed structural systems (4.3).
                                                              ∑ M DEV ≥ 0.75 M o                                                       (4.3)
Possible solutions:
  • Shearwall / shearwall group can be added to the structural system until the 4.3 condition is met.
  • Solution can be made by choosing high ductility level. ( A14 or A15 )
  • In buildings with BYS> = 7, a solution can be made by selecting the A31 system type.
Icons:
