New Layout Block-Circle
With the New Layout Block-Circle command, objects inside a drawn circle are cut and saved in the memory or archive in the working drawing window.
Location of New Layout Block - Circle Command
You can access it under the Ribbon menu drawings tab, Layout Design title.
  • Click the New Layout Block - Circle icon.
  • Click in the drawing area. The point you click is the center of the circle.
  • Move the mouse. Determine the diameter of the circle and click again.
  • Click any point in the drawing area. The point you click will be the insertion point of the block.
  • The Layout Block Settings dialog will open. In this dialog, give a block name and set the scale.
  • If you want to indicate the perimeter of the block with a line, check the Draw border line.
  • If you leave the Save to library line checked, the block will be saved in the archive.
  • Click the OK button.
Determining the center of the circle
Determining the radius of the circle
Determination of insertion point
Layout block creation
Insert Layout Block
