By selecting the previously assigned texture, surface or object with the edit surface mapping command; scale change, angle, translation, mirroring editing is made. The changes made are followed simultaneously from the perspective screen.
Location of the Edit Surface Mapping Command
You can access it under the ribbon menu Rendering tab, Render title in the architectural program.
Click the Edit Surface Mapping icon.
Click with the left mouse button on the surface whose material you want to edit in the perspective window.
The Projection Parameters dialog opens automatically.
Make the arrangement you want. You can follow the changes you have made in the settings from the perspective screen.
After the settings are made, complete the texture editing process on the selected surfaces by pressing the OK button.
Before edit surface mapping
Clicking on the surface whose material is to be edited and changing the angle value to 45
After edit surface mapping
Fit to surface Places the texture to cover the selected surfaces. |
Repeat count Repeats the texture for the values entered on the selected surfaces. |
Dimensions Texture length is determined by entering values in two directions. |
Keep aspect ratio If checked, the texture is edited by entering a value in the U box from the number of repetitions and dimensions lines. |
Worl length Texture length is entered. |
Angle
Texture angle is entered. |
Offset U
The motion value of the texture in the x-plane is entered. |
Offset V
The motion value in the y-plane of the texture is entered |
Mirror U Symmetries the texture with respect to the y plane. |
Mirror V Symmetries the texture with respect to the x-plane. |
Material Existing material is shown. A different material can be defined by clicking on the down arrow button with the left mouse button. |
