Maximum Percentages in Beam Exceeded.
This message is created at the beginning of the report by giving the element name and solid.
For example, K1 1st floor Maximum pursuit exceeded
In the element given its name and solid, it means that the required reinforcement ratio calculated from the design effects exceeds the upper limit reinforcement ratio given in the regulation.
Possible solutions:
  • The analysis should be repeated by enlarging the sections of the relevant element.
