Trapezoid Sloping Right Truss
With the Trapezoid Sloping Right command, the trapezoid sloping right truss type, which is one of the prepared truss types, is drawn quickly. Truss heights are adjusted from the truss settings.
Trapezoid Sloping Right Truss Schematic Drawing:
Location of the Trapezoid Sloping Right Command
  • Click on the trapezoid sloping right command.
  • In the Heights tab , enter the heights h2 and h4 for trapezoid sloping right.
Entering 80 cm for h2 and 120 cm for h4 in the height tab of the truss settings
