With the T Plate Connection command, beam-beam connection is defined.
Location of the T Plate Connection Command
From the Connection menu, click the T Plate Connection icon.
The T plate connection settings dialog will open.
Location of the T Plate Connection Settings Dialog
Type Tab
Plates
It is chosen whether the plate will be on the left or right of the beam body. |
Schematic drawing
The connection is shown on the schematic drawing. |
Preview
There is a preview of the combination. The selection made and the entered values can be followed simultaneously in the preview. |
Plates Tab
T plate
The properties of the plate are determined by entering the values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Top and Bottom Notch Tabs
Notch
If the option is selected, notching is done according to the entered values and selections. The values to be entered are shown in the schematic drawing. |
Left flange cut
If the option is selected, left header flange is made according to the entered values. The values to be entered are shown in the schematic drawing. |
Right flange cut
If the option is selected, right flange cutting is made according to the entered values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode The strengths of the welding electrodes are defined in the design inputs. The strength of the main element in the weld joint is controlled under the condition that it has less strength than the weld strength. If necessary, click the list and define "Create New…". To create the welding electrode, give the information "Name" and "Weld metal tensile strength" in the dialog that opens after clicking "Create New". Welding geometry is determined automatically by the program. These properties can be changed to easily determine the connection properties. Geometry features are in accordance with industry standards and in the form specified in AISC.
Schematic drawing
Connection and source values are shown on the schematic drawing. |
Preview
Chamfers Tab
Chamfer (c1)
Chamfer (c2)
Schematic drawing
Preview
Beam Bolts Tab
The properties of the bolts connecting the plate to the beam are adjusted.
Horizontal arrangement
Horizontal arrangement settings (number of horizontal bolt columns, distance values ..) of beam bolts are entered. The values to be entered are shown in the schematic drawing. |
Group 1
Beam bolts settings (number of lines, distance values ..) are entered. The values to be entered are shown in the schematic drawing. |
Bolt properties
Schematic drawing
Preview
Design Data Tab
